I was reading the "what's new" document for ORD 2021 R1 and I saw this:
What does this mean? Is this tool still available for those of us who do not use ProjectWise?
So...instead of making it default to a standard installation without ProjectWise, Y'all decided that it should default to a ProjectWise environment?
ProjectWise is not a prerequisite for OpenRoads Designer and we should have full functionality out of the box without it. I don't see your "instructions" to edit the PW.CFG file anywhere in the documentation. I don't understand HOW IT is supposed to "know" that. And your interpretation that "It is impossible to anticipate how each company is structured" rings with a lack of imagination, if not laziness to consider at least a few different options.
It is NOT unusual for users to NOT have administrator privileges.It is NOT unusual for the IT people who do the software installs to NOT be the people most knowledgeable about the finer details of every software they touch.It is NOT unusual for a company to have OpenRoads Designer without ProjectWise.
None of these is an exotic concept. Pretty standard operating procedure, in my experience.I get more and more frustrated by Bentley's disregard for standard business practices and actual working user experience. This company is moving, philosophically, away from a practical solution grounded in engineering practice and more toward an ivory tower of ideals with little to no concern for how the work actually gets done.
MaryB
Hi Mary,
That PW cfg has always been there, but it just about disabling that cfg to get past the bug with the tool trying to access ProjectWise for users who dont have it. A hole in the testing of the tool before release I think...
Mark
Mark Shamoun said:A hole in the testing of the tool before release I think...
Nothing new there...
Instead of editing the pw.cfg file (which most standard users can't do) you can accomplish the same thing by making a custom ORD 2021 desktop shortcut and add this at the end of the Target.
-wsPW_DISABLE_INTEGRATION_FROM_DESKTOP=1
Rod WingSenior Systems Analyst
With the stand alone CivilFileManager.exe Not the downgrade function within ORD
CivilFileManager.exe does not have
-its own pw.cfg,
-or use ORD's pw.sfg,
-or recognize the startup switch -wsPW_DISABLE_INTEGRATION_FROM_DESKTOP=1 , (It won't start with it)
So when adding file to process in CivilFileManager.exe, even without PW installed it is attempting to log onto PW, and crashing.
Another tool designed and built without the Bentley asking "What if the user....."
