Linear Template - Updating with vertical adjustments
Hi
I'm using Power Geopak V8i SS10. Very new user.
I am working on modeling an intersection. I have laid out a pavement/wearing surface with edge of pavement lines. I applied my curb & gutter/sidewalk/tie as a linear template to EOP lines. When adjusting the vertical geometry of the eop line, the template does not update to corresponding vertical. Is a linear template not dynamic or tied to this line? Or is it and I need to rebuild the "corridor" somehow?
As always thank you for your help!
Parents Reply
  • Okay - I did notice when I adjust the centerline/crest of the road it updates, which was added as a breakline. When I move the edge of pavement ( which was added as the boundary) it does not update. Do I need to add the boundary lines as breaklines too?
    Any insight on the linear template not updating automatically? It does update if I go to the project manager, civil objects, process corridor. Do I have to do this for every linear template?
