We are pleased to announce that OpenRoads Designer 2021 R 1 is now available.
Below are just a few of the enhancements you’ll encounter in this release.
General Enhancements
Drawing Production and Annotation Enhancements
Drainage and Utilities Enhancements
Item Types Enhancements
Please refer to the ReadMe for a comprehensive list of changes and enhancements.
https://docs.bentley.com/LiveContent/
Did you fix the "dancing annotations" issue yet?
You know... the issue that makes the software almost unusable for roadway plan production?
communities.bentley.com/.../how-to-stop-annotation-text-from-updating
Mark - yes, we fixed the issue where annotation was "re-firing" when the underlying geometry had not changed. However, keep in mind that when the underlying geometry changes, the annotation will 're-fire" and move back to it's original position - that is currently working as designed. We will address this in our next release - so that annotation will re-evaluate (ie. change the appropriate values) but still hold it's current position
This release (10.10.00.81) is no longer visible in the Software Downloads. I don't see the parallel OpenRail Designer version either. Were they pulled for some reason or is this a fluke?
Errick - Yes. I just posted this to the announcements forum.
Hi Derrick - will you please assist with where I can find the announcements forum. When will OpenRoads be available?
ZUTARI SOUTH AFRICA
