Hi guys,
My collegues discovered that it's impossible to move any circles geometry without changing their radii.
1. step - draw a circle - tab geometry->hoirizontal->circle
2. step- grab the center of circle in order to move it
3. result: circle increases radius. it seems to me that the circles are defined by 3 parameters/constrains: xy center, xy point thru, radius. I get the impression that the strongest constrain is xy point thru...
How to fix it? What's all about? I can't remember that problem occured in previous version of ORD.
Cheers,
psz
Thank you.
Not very intuitive, that. Not incorrect, but not the first tool I would think to use. Thank you!
MaryB
I've never actually used that Transform tool prior to. Does it basically just remove rules, move, then reapply all in one button?
The help doc says "If civil elements are transformed, they become simplified elements, meaning if the element is a target of a rule then that rule is removed. A warning box appears if civil elements are about to be transformed."
Transform (bentley.com)
Matt
