I updated my XS annotation group in the .dgnlib file at this location (C:\FDOTConnect\Organization-Civil\FDOT\Dgnlib\Feature Definitions)
But when I cut my cross sections, it doesn’t reflect all the changes I made.
How can I make the software recognize the changes I made and reflect it on my XS? Thank you for your time.
If you had already used the 'old' XS annotation group, it would have been copied int othe DGN file - so any changes to the DGNLIB would have no effect. You have to delete all the annotation in the DGN, delete the Annotation Group and Annotation Definitions in the DGN, and then re-annotate.
As the DGN is now clear of any old Annotation Group, it will now look at the DGNLIB and take the updated information.
Answer Verified By: Phani Gubbala
Rather than delete out of date annotation groups definitions can you use the "Update Standards from DGNLIB" option from the OpenRoads Standards Explorer dialog? Then remove and reannotate the cross sections. This options should update all standards from the DGNLIB.
Mike LongstreetVermont Agency of TransportationCivil Engineering Technical SupportVTCAD Help
Thank you for you time.
I will try this too. Thank you so much!
