Hi Everyone,
I am currently trying to export my cross sections from open roads designer to DWG auto cad format.
However no matter what setting I try on my export the DWG files seem to contain the 3D model (as shown) I have tried disabling 3D settings within the References Tab within the export utility with no luck.
Any ideas?
Thanks in advance!
Chris, Have you tried using Cached vs Dynamic Settings in the reference Manager?
My guys had issue with this, which resulted in them creating a copy of the sheet and merging the references in the copied sheet prior to export, this worked a treat.
Chris
AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
Associate Director – Digital
OpenRoads Designer 10.11 | MicroStation CE 10.17 | ProjectWise CE 3.4 | ContextCapture | ProjectWise PowerShell 2.0 | Generative Components | OpenBridge Designer 10.11
Revit 2022 | Civil 3D 2022 | Recap 2022 | Infraworks 2022 | Dynamo | Navisworks Manage
PowerShell | Visual Studio | Office 365 | Power Automate | Teams | SharePoint | Visio
Speckle | BIMVision | Revizto | Solibri
Hi Chris,
Make sure this setting is enabled in your DWG export options.
Mark
OpenRoads Designer 2022 R1 (10.11) | Microstation CE Update 17.2 | ProjectWise CE 3.4
Thanks for the fast response! Are you able to snippet exactly where this change is made? I cant seem to find it, I assume you mean within the references where my models are referenced?
Hi Mark, I did try this, then nothing appears, only annotations (data bands, levels etc) Thanks for the response!
with attachments set to merge?
