Hi
I updated OpenRoads Designer to 2021 R1, now I wonted to do the same for OpenRail Designer and it seems this latest versions are removed from the Bentley Server.
I have already updated few of my dgnlibs to 2021 R1 and looks that 2020R3 will bit see updated linraries. They will not load with the workset.
Is there any reason for which 202 R1 was removed from servers?
Adam
is it safe for projects to use 2021 R1?
Best,
OpenRoads Designer 2023 | OpenRail Designer 2023
I have heard a rumour there is a critical issue with Cross section annotation apparently. The only issue we have found is they Key Station graphics are broken when you adjust them, although they still apply correctly.
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
Answer Verified By: Adam Wieczorek
As Mark has said, their is a critical issue with Cross Section Annotations. I'm still using it (to get things setup and modify my workspace) but I'm not allowing any of my projects to install it and will wait for a new version to be released (and test that again) before I recommence rollout.
Chris
AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
Associate Director – Digital
OpenRoads Designer 10.12 | MicroStation 2023 | ProjectWise CE 10.3.4 | ContextCapture | ProjectWise PowerShell 2023 | ProjectWise WSG API | Generative Components | OpenBridge Designer 10.12
Civil 3D 2023 | Dynamo | Navisworks Manage
PowerShell | Visual Studio | Office 365 | Power Platform | Teams | SharePoint | Visio
Speckle | BIMVision | Revizto | Solibri
What they need to do is hire a retired 70-year old roadway engineer as a Consultant. No ORD Release can go live until the programmers/developers can get an ENTIRE Set of Construction Plan Drawings past this guy and his dreaded Red Pen......
Just a thought.
