Hi All, Hoping to have some advice on the following.
When i run through the prompts of calculating super elevation once this has completed, nothing seems to apply to my lanes, nor does anything appear in my super elevation editor or superelevation viewer
It seems to me as if something is not applying correctly here!
I have created a super elevation section (tried both by using corridor and alignment) Section seems to create fine,
Created lanes left and right (I have tried using both manual and template with no luck with calculation tool)
I have followed the Bentley training videos and subsequent you tube super elevation tutorial videos to an absolute tee with no luck with calculation tool.
I have tried different rule files including the training files, ANZ (Austroads, MRWA) with no luck with calculation tool.
I have also tried running the calculation tool once the super elevation has been applied within my Corridor file, saved this, then went back into my super elevation file and ran calculation tool - no luck.
I have referenced in Terrain, Geometry (Live Nesting 1) , Corridor (live nesting 1)
Nothing seems to work! any help would be greatly appreciated! Please feel free to clarify anything I may have not noted here!
In the image above, I note all the cyan ticks in the dialog. They normally mark start and end of transitions - yet there are way too many of them for the alignment you display. Where is the alignment coming from, and can you show the horizontal report for it?
Hi Mark, The alignment is referenced from my geometry file,
Can you run a Horizontal Geometry Report on the alignment - I do not understand why there are so many ticks in the Super dialog.
I seem to be getting an error when generating this? Not sure what this mean. I will have to investigate further
