Hi All, Hoping to have some advice on the following.
When i run through the prompts of calculating super elevation once this has completed, nothing seems to apply to my lanes, nor does anything appear in my super elevation editor or superelevation viewer
It seems to me as if something is not applying correctly here!
I have created a super elevation section (tried both by using corridor and alignment) Section seems to create fine,
Created lanes left and right (I have tried using both manual and template with no luck with calculation tool)
I have followed the Bentley training videos and subsequent you tube super elevation tutorial videos to an absolute tee with no luck with calculation tool.
I have tried different rule files including the training files, ANZ (Austroads, MRWA) with no luck with calculation tool.
I have also tried running the calculation tool once the super elevation has been applied within my Corridor file, saved this, then went back into my super elevation file and ran calculation tool - no luck.
I have referenced in Terrain, Geometry (Live Nesting 1) , Corridor (live nesting 1)
Nothing seems to work! any help would be greatly appreciated! Please feel free to clarify anything I may have not noted here!
I meant Geometry that does not include Curves. Do you have a snapshot of the geometry?
Mark
Sure no worries, regardless with or without these referenced my calculations are not working or applying
My Curves have a radius length of about 230m from tangents
What happens if you tick "Open Editor" on the dialog and run it?
