For some reason my MAIN toolbox will not stay on in OpenRoads when I exit out and go back into the program. All others will appear, including Custom made Toolboxes, but I still have to reopen the MAIN tool box each time I open the program new.
Hi Rick,
The issue is due to an already logged defect #1115302 on MicroStation platform. As a workaround, you can toggle on V8i based Task Theme which has a 'Main' set of tools built in. communities.bentley.com/.../enable-v8i-task-theme-in-microstation-connect-edition
@karan
Are there any known issues with using the Task Theme? According to this thread, there were still issues: https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/191773/ord-2020-r1-enable-task-navigation-like-ms-u13/566564#566564
MaryB
