Hello all. Working in ORD Connect. I am working on a divided hwy with two PGLs, each with their own template drop. My typical section has 6:1 tie towns from both sides in the median forming a ditch. How do I get these 6:1 tie downs to target each other or is there a better method?
You can use Target Aliasing to target the slope of one corridor from another. You could also use a HV corridor control point to have the 6:1 v ditch generated from one corridor tie to the shoulder point of the other corridor. Either method will work, but neither method will allow you to control the ditch profile which may not be important to you. If the v ditch profile is important then you'll need to vary your slopes; left, right or both, to accommodate the ditch profile. HTH
