I know my question involves a process in OBM, but the technique was originally done in ORD hence why I'm asking here. That and nobody was answering my question in that forum : ). Does anyone know how to create pavement markings from an OBM deck/solid? I was trying to follow the video below, was able to offset my alignment to create the alignments of my pavement markings, but when I got to the point where I needed to create profile from surface it wasn't working. That makes sense since the deck is a solid as opposed to an ORD surface like in the video, so I tried profile by 3D element as well and that was not successful. So any ideas how we can accomplish what they do in the video but in OBM?
Thanks!
https://youtu.be/U71PB8dObKI?t=92
_
OpenBridge Modeler - 10.10.00.85Microstation - 10.16.02.34
Comprehensive 3 Day OpenBridge Modeler Training
Hi Steven,
How about using the Mesh from Element tool (with Keep Original enabled) and then the Profile from Surface command?
Mark
I used to use Extract Faces/Edges tool. You need to have a point in a deck cross section to get that edge in a solid. That will give you 3D smartline. Hope it helps.
