Hi ,
how can I create transition between road/rail and wall to continue from wall to fill , here is picture from very old video ORCS presentation and I have no idea hoe to make it
karol
Changing your template transition length between the wall template and the fill template to zero will resolve most of your problem. You will then need to address how the slopes at the beginning/end of your wall tie to the existing ground if the proposed elevation delta where you change from fill slope to wall is anything other than zero. You could build that transition into your wall template, add another component to base the transition from or just ignore the transition and have them resolve it in the field. HTH
Hi PEvans,
thanks for your response, it really works in OpenRoad CS , but my problem is to make the same in OpenRail CS ,very curios
I made a step by step tha same procedure without good result , maybe is a bug
There is an entire forum dedicated to OpenRail: https://communities.bentley.com/products/rail_design/f/openrail-forum
Perhaps you should ask there, in case there are specific OpenRail requirements that we road folk might not know.
MaryB
