I built geometry based on an alignment. I moved the alignment 3.5'. The geometry should shift along with the alignment right? When I open the design file, where I have all my geometry, the geometry doesn't move. The inside edge of pavement (EOP) on either side of the alignment is at 11' offset from the alignment. When I select the EOP the offset shows up as 11' but when I measure the distance it is 14.5', the geometry did not move. Is there a way to refresh the geometry? I tried to change the offset to a different number, lets' say 11.5', the EOP shifts but after the change it won't change the offset, even if I enter a different value. Thank you for you time.
I believe it all depends HOW you created that geometry, and whether you have rules locked or not.
MaryB
When I stayed in the file for sometime it automatically adjusted itself. Weird, but I will take it.
