In the Connect Edition we have the DGNWS file which is where the sheet index information is stored. That sheet index has folders for all disciplines sheets, so all disciplines sheeting information will be stored in that single DGNWS file as part of the cadd deliverable. Since different consultants/companies work on different disciplines for a single project, their files will be stored in their own respective repositories (separate DGNWS files). Since the cadd deliverable will be a single DGNWS file, those different companies DGNWS files will need to be merged I assume? Is there a documented workflow for how to do this? What has everyone else been doing in this scenario?
Thanks!
A recent post with a mention regarding opening DGNWS files to edit properties intrigued me to start digging. Has anything be discovered on the ability to merge or add information from one DGNWS to another? I've known previous version of Bentley allowed drag and drop directly from the Models dialog of two open DGN files. Could this be possible with two open DGNWS files? If so, either respective models containing the required info (separate discipline folders) and or drag and drop from the sheet index itself... Curious to being some testing on this.
colliersengineering.com
