strip grades OpenRoads Designer
Hello-
We have created annotation groups to display profile strip grades, both existing and proposed.  We have feature definitions and annotation groups assigned to both existing terrain and to the proposed design profile.  When testing, we can get the proposed strip grades to show but cannot get the existing strip grades to show up unless the terrain is active (not referenced) in the design file in which we're annotating.  Has anyone else run across this and what did you do to fix it?
This is what I'm seeing when the terrain is referenced and not in the active file.
When I create the terrain in the file that I'm using for annotations, I see the correct result shown below.
