I have been trying to build an ORD feature definition dgnlib. I had three dgnlib files in the workspace feature definition folder, I removed two of the files, but they are still showing up in my standards library. Also the dgnlib that is left in the folder is not showing the updates I made to it. What am I doing wrong? I also can not update standards from the library. Any input would be awesome. Thanks!
Paul
Hi Paul,
I recommend checking the paths defined for the MS_DGNLIBLIST config variable. This is the main variable that controls which dgnlibs get loaded by the dgn in a particular workspace. Check the paths and make sure that there are no duplicates of the dgnlibs that were removed or an older version of the dgnlib you updated. If there are duplicates, then you should remove them. If there are duplicates, then that could be the reason that the update standards from library tool does not work properly for you.
