Equally spaced point between two alignment in templates
I have a task where I need the central points in the attached image to always be centrally located between the left and right rail origin points. Whilst also maintaining the V shape. Each rail origin point will be assigned to an individual alignment using point control.
Is there a way of constraining the points so the above is achieved?
 Thanks in advance
