You used to be able to bring boring logs from gINT into Geopak and they would show at the correct elevation and location in existing ground profile. Is Openroads still capable of accomplishing this? I have already gone through the Geotech workset training and it does not touch on this.
Hi Yeh
Once you switch to the Geotechnical workflow in OpenRoads Designer, boreholes can be read from an Access database, a Microsoft Excel database or from a SQL Server database, see more here:
docs.bentley.com/.../GUID-079A6246-47F3-4791-A9F4-5A2BD2B00F25.html
