I notice that a new UK dataset is available this morning, to coincide with the new release of ORD.Will this new dataset work with older versions of ORD or will it only work with this latest release ?
The data will likely be in the 10.10 file format and would have to be downgraded using the Civil File Manager if you want it in a previous version.
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/51904/downgrade-civil-model
I am new on this forum and replying to this post as I cannot find tab for placing new post.
I watch one of the tutorial video of Chris on Inroad Bridges and created two span continuous bridge. It is somehow not taken my setup of bearing line at the PIer which I create using Create Abytmnet/Pier CL Bearings by using BEARING AHEAD and 0 distance as it is continuous. I then created all the girders and vertical. it seem all this is done successful and they all are appearing when I use DISPLAY BRIDGE. When I created the BRIDGE REPORT, I found it is not displaying BL2 and it seem like it is taken two span as one span. Also, I am seeing some information which seem not correct in the report. I think all this is because of not considering BL2 at pier as a support. Can someone help ? I can share the ALG file
