Ive been working with extracted lidar that was done in MS Connect and I need to bring it into ORD Connect Edition (Version 10.09.00.91) and create a Field Book that will then be exported as a Bentley Survey Format (.SQLite) and then imported by the surveyor into their ORD dgn with their own (separate) field book. The export seems to work just fine, and the first few times I tested an import in a new ORD DGN it seemed to work, but all of a sudden I cant import the SQLite files anymore. The process goes through and the graphics do appear on screen but the Linear Features don't show up in the Field Book, and if I uncheck the field book the graphics remain on screen proving they aren't in the field book. So it looks like ORD is importing the graphics but not bringing the Field Book attributes along with it. Again, it worked the first handful of times I tried it but no longer does.
Also, if I send the SQLite file to a co worker it can be imported correctly on a slightly older version of ORD Connect Edition but I'm not sure its the version since it worked the first few times I tried it.
Chris,
I'm encountering the same issue as well. It's a good thing that someone from Bentley has gotten back to you about a fix for the problem.
I have also submitted the issue to Bentley tech support. The support staff have provided me with the following Defect Report 1116425. I'll post back here if I receive useful information or an update of any sort.
Take care,
Cliff
I have also experienced this issue and filed a defect in Sep 21 - 7001305960. Note that you will also lose any descriptions/notes that are placed on the linear features. If you use VBA macros on points, they export with the sqlite file, but do not import into a new survey fieldbook. ORD 2020 10.08.01.33
