I'm processing a survey and would like to review the log file as the software seems to be ignoring ST codes and/or Close codes. The recommendations by other suggest after using Link Codes to define the import, it is better to then save the figure by Point Lists. But when ST or CL codes are ignored, the cleanup of point list figures requires more edits as you have to break figures into separate figures and then delete the figures that originally joined the figures which remain.
I do not know if the log file would help, but without knowing where it is created, I can't even investigate its contents.
BUMP!
I almost posted a new question only to discover I already asked, but no one has responded!
I don't see any variables to change location or name, but the default location is the directory of your dgn and the name is "Default.log"
For more information about the Road and Site design tools, visit the Road and Site design WIKI at:
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
Answer Verified By: caddcop
We use ORD exclusively within ProjectWise - I see no evidence of the log file within that environment.
But locally, the filename appears to be [model name].log.
