Superelevation not showing on first profile sheet
While creating profile sheets I am finding that the superelevation section of the table displays correctly on all the sheets apart from the first one.
On the first sheet it looks like the left image, and on the rest it looks like the right.
As you can see the superelevation is applied from the very start of the line (including the negative chainage), and the annotation group contains all the required fields.
Any ideas what could be causing this?
Parents Reply
  • Thanks, this is really helpful. Essentially, if your plan groups named boundary starts before the alignment (which mine does) then this will happen. As a simple fix for now, I have created a new profile named boundary using station limits. This won't be a part of a plan group though, so it needs to be referenced into the drawing separately. I've just tried this and it has worked perfectly. Thanks Mark.
    I'll still look to put in a ticket as well.
