I was wondering if I can use configuration variables to setup my Geopak Survey default preferences (SDP) file. Specifically to define Project Directory, Job Directory, Global Working Directory, and Dataset Output Directory. I would like to set them to $(_USTN_PROJECTDATA)Geopak/ and $(_USTN_PROJECTDATA)Geopak/Survey/.
Will Geopak Survey recognize this?
Geopak 8.11.05.39 and Microstation 8.11.05.17
I had someone try this and it is not supported. I'll see about getting it supported for a future release.
Derricke
We've created a ticket on it in order to make the change so it will support it.
Has the change been implemented? If so, how do I do this?
