Edit un attached surface created from survey points
I created a surface from survey points but not linked to them since the surface is too big. now I have to edit the elevations of a data file but if I do since the surface is not attached nothing happens. is there an easy way to remove a datafield file from a surface? without having to remove each point from the surface individually? o what do you suggest is the best way to go about doing this?
