how would I open .xsr cross-section file?
With what software, and which version of which software? What do you have and what are you hoping to do?
MaryB
Thank you for your immediate response Mary!
Geopak SELECT series 10. I want to use .xsr file from old project to a new one. What steps should I take ?
Thanks Mary !
This may not be possible. If I remember correctly, an XSR is simply a cross section report ASCII file generated by the XS List command. It is a list of whatever data you requested at the time it was run. An XSR is not a settings file. Since it is an ascii file, you can open it with any text reader like Notepad or Ultra-edit.
Unfortunately, the XS List commend does not have any way to save or recall previous settings used to generate reports: https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/96185/importing-xsr-cross-section-file-into-geopak
If you want to use the data from the XSR to generate a new surface, that might be a different thing and I'm not sure offhand how that would be done.
Thanks Mary,
How can I retrieve cross section settings file from old project? Where is it actually stored?
Cross section (XS List) REPORT settings are not stored anywhere, unfortunately.
In OpenRoads SS4/SS10, cross section settings (as in preferences to generate cross sections) are saved into the XIN file - if they were saved.
I honestly can't recall where settings were saved for the older methods. I believe they were ascii files that could be named anything, but I could be wrong. Hopefully someone who has worked in Geopak more recently than I will be along shortly.
