I have created a Dgnlib that will contain seed models for various tables we use. I can currently click on the Place Table tool, and then select the correct Table Seed from the drop down box. I would however like to automate this process using the Key-in function of a custom tool.
Is there anyway to tell ORD to select a specific Table Seed once that Place Table dialog window is open?
I can Key-in the following: Place Table Empty
This brings up the Place Table dialog box, but I need a way to Key-in a specific Seed. The end result would be a custom tool in the ribbon that when clicked, would place that OASISLOOP Table.
Thanks!
Nick
