template drop behaviour around sharp corners
is there a way to get a template to go around sharp corners like illustrated in the screenshot?
What i'd like the the baviour like the multiline above the corridor with trimmed inner corner and extended outer corner geometry
  • In the past in these "bowtie" type of areas, I have addressed overlapping end conditions by placing an element that extends out from the vertex and targeting that. You can set a profile on that element to control elevation, similar to how a ditch or gore area would function. Not sure if this specifically addresses your issue, but thought I'd offer that method.
    Eddie Giese, PE
    Production Manager | Senior Roadway Engineer
    Licensed in FL & PA
    ACEC FDOTConnect Instructor on behalf of FDOT
    Patel, Greene & Associates, LLC
    PowerGEOPAK V8i SS10 (08.11.09.918)
    OpenRoads Designer 2021 R2 (10.10.21.4)
    OpenRoads Designer 2020 R3 (10.9.0.91)
    ProjectWise Explorer CE 10.0.3.453
    LumenRT CE Update 14 (16.14.60.98)
    premier-scholar-badge road-designer-badge
  • You could have a point control on that outer edge, but what else is that last bit of line controlled by otherwise.
    As example...Simple template with 2-12' lanes, each sloping away from the centerline at 2%. You can even control the width with point controls along a feature. When you get to that corner, your centerline goes somewhere else. Even if you had the outer edge controlled by a point to a feature, there is no longer a centerline in that region to take the slopes from.
    Actually, how would you define those elevations? Flat from the end of the alignment? Continuing the profile grade along the edge? How would that transition to where the outer edge "picked up" the centerline again?
    Multilines are a very different, very old, 2D technology and there is very little design logic to them. A template is a complex design of relationships in 3D, so making that kind of (apparently) simple extrapolation really involved.
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
