Is it possible to turn off the "Persist Snaps and Rule" function by default.
I dont wish to use it anytime, therefore i wish to turn it off by default, so i dont have to do it every single time i open the program.
Best regards
Klaus
Hi Klaus,
Technically you could add the "geometry snappersistence" keyin to an autorun macro that toggles it off on start every time. I don't know of any other method right now.
Mark
Answer Verified By: Klaus Thystrup
Thank you very much
