I have activated the dark theme in ORD 2021. It looks good except for the menu color (Home, Geometry, Terrain, Drawing Production, etc) which is almost not visible. Is there a way to change the text in the menu to be black so it can be seen?
MarcPDF
Hi Marc,
You need to restart the session to get all the menu colour changes to apply.
Please note that text in Corridor Objects, Superelevation Editor, Annotation Group Manager, Complex Terrain, etc. will display white on white and only have text visible on seclection - logged as a defect to be fixed (hopefully for the next release).
Mark
