Hi
What's the best practice to merge Terrain Models in ORD? Especially very large ones.
The only two options I can see are:
I feel like this used to be much simpler pre-OpenRoads.
You can deactivate the rules on a complex terrain. This will fix most issues with complex terrains.
Zane Pratt
Civil Designer
Are these terrain models survey based?
I didn't know I could do that, thanks! The problem is still that ORD crashes before it finishes creating the complex terrain. I'd like to perform the merge without it creating those rules in the first place.
The terrain models aren't extracted from survey files but are built from TIN files.
