Hi guys,
I have recently updated my ORD version from 2020R3 to 2021R1. Mostly everything seems ok but I have encountered slow opening speed of sheet model display. I captured the screen for comparison. This issue was also a problem in 10.07 version and corrected in following releases but now it occured again. I appreciate any suggestion as browsing through sheet models is a common practice.
ORD 2020R3:
ORD 2021R1:
Hello again,
Is this issue reported to Bentley Dev team? If there is not any solution by now, we will unfortunately downgrade ORD to 2020R3.
I just want to ask if there will be any improvements in ORD 2021 R2 about the "Slow Sheet Model Opening"?
Hi Erdem,
Did you get a defect logged for this one? We have the same issues but haven't had time to be able to reproduce it clearly to Bentley support.
Mark
Hello Mark,
I captured screen for comparison of 2020r3 vs 2021r1. But I haven't submitted a defect. Actually I think this will be considered as a defect. This was a solved problem previously and appeared again.
best regards,
OK thanks Erdem,
Do you know what resolved it? We've found it only happens when there is any change in the 3d model, Inc. Level display change, reference change, etc.
