Hi guys,
I have recently updated my ORD version from 2020R3 to 2021R1. Mostly everything seems ok but I have encountered slow opening speed of sheet model display. I captured the screen for comparison. This issue was also a problem in 10.07 version and corrected in following releases but now it occured again. I appreciate any suggestion as browsing through sheet models is a common practice.
ORD 2020R3:
ORD 2021R1:
We normally create a new Projectname_XS.dgn and reference Projectname_corridor.dgn to it. As we have completed the design stage and producing the sheet models any change is not expected on both files. I've witnessed sheet models only open slowly in 2021R1.
I dont see this issue in Microstation CE Update 16.2 so hopefully that behaviour continues with 2021 R2 which should come shortly...
Mark
Mark Shamoun said:continues with 2021 R2 which should come shortly...
Isn't it too late to release 2021 R2? ;-)
But I agree, the release based on CE U16.2 power platform is desperately needed.
Jan
From what I've been told it was due at Christmas, but looks to be delayed from some last minute issues. Not sure if they will bother rebranding it if it comes out very early in the new year, but who knows...
Hi Mark,
Do you know if there is any progress in solving this defect?We are experiencing slow display of sheets with cross sections in ORD 2021R1. For example to open sheet - for the first time when creating cross sections - with 25 cross sections it takes 7minutes while "Update in progress" is shown in the prompt. In ORD2020R3 the same sheet opens instantly even at first time during XS creation. Will this be addressed in the upcoming new release? Regards,Mariusz
Mariusz
OpenRoads Designer 2022 R1
