How do you change the Horizontal Baseline geometry of a Corridor? Can you change the Horizontal / Vertical baseline geometry of a corridor? I have a corridor where it appears to have lost its association to the original baseline Horizontal geometry. The properties of the corridor show a blank where the "Horizontal Name" and Profile Name" were and should be. The horizontal geometry is still reference into the file so I would like to relink it. The corridor does seem to work like it has a geometry but the original geometry did change (direction) some and the corridor does not follow the new alignment.
If I cannot re-associate will we will need to start over with a new corridor and redo all the work for that corridor.
The video below seems to do the trick.
communities.bentley.com/.../video-reattach-corridor-with-openroads-designer-connect-edition
Mike LongstreetVermont Agency of TransportationCivil Engineering Technical SupportVTCAD Help
I'm glad to see I'm not the only one who often ends up talking to himself on these forums!
