When will Migration Utilities be upgraded for 10.10 release. Specifically with the ability to define Item Types associated with Feature Definition.
Chris - have you finally gotten an answer to your question? I'm also interested to know as well...
Not to my knowledge
Chris
AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
Associate Director – Digital
OpenRoads Designer 10.12 | MicroStation 2023 | ProjectWise CE 10.3.4 | ContextCapture | ProjectWise PowerShell 2023 | ProjectWise WSG API | Generative Components | OpenBridge Designer 10.12
Civil 3D 2023 | Dynamo | Navisworks Manage
PowerShell | Visual Studio | Office 365 | Power Platform | Teams | SharePoint | Visio
Speckle | BIMVision | Revizto | Solibri
Please update the status of this. If the Schema hasn't changed from 10.09 2020R3, someone from Bentley should say so, and update the documentation on the WIKI indicating that the latest Migration Utilities are valid for 2021 R1.
If it has changed, when are the new Migration Utilities going to be provided? Chuck Lawson
I need to know about the status of this as well. I am trying to research a problem with a couple of DOT workspaces and I thought I would quickly produce and XLXS file from their Feature Definitions to help me. But stopped as I do not want to waste time using utilities, which will probably not work.
Please advise as to the 10.10 status?
I just found out that the migration utilities are now added functionality to the software itself such as the Feature Remapper. Those tools can be found in the Backstage under Civil Tools. This is an improvement that I did not catch, when 10.10 came out.
