Is there a way to tell if a file was created in Microstation or OpenRoads? They are both called "dgn's" and look the same. Help please!
Hey Brian,
I'm not certain if there are means to determine which program engine was used to create a MicroStation Design File (i.e. *.dgn). However, you can view which program was used to last modify a MicroStation Design File.
To do this:
I hope that this helps some.
ProjectWise Explorer CONNECT Edition, Version 10.00.03.453
ProjectWise Drive, Version 2022.1.328
OpenRoads Designer CONNECT Edition, Version 10.09.00.91
OpenRoads Designer CE 202 Release 2, Version 10.10.21.4
Power GEOPAK V8i (SELECTseries 10), Version 08.11.09.918
