Is there a way to import .tif aerial photos into Openroads Designer? I imported the point cloud and have created a terrain, but now I would like to import the .tif files that the drone captured. Is this possible to do? I'm working in OpenRoads Designer CONNECT Edition.
You can use Raster manager to attach image files. If they have a GCS, they should come in right in place.
I believe there is a way to attach an image as a material to a terrain, but I wouldn't know where to start.
MaryB
You can also create a reality mesh from these images and point cloud with ContextCapture and import this directly into OpenRoads
