Currently I am on a project where I'm detailing signs. One of the signs is a "X% GRADE" sign and requires the use of the Highway D 2K font. When I attempt to input the percent symbol a black box appears instead. See below for screenshot.
I've noticed that when I switch to another font loaded onto my SignCAD (like Clearview Highway font) the percent symbol does appear. Is there anyway to get the symbol to appear on the Highway D 2K font? Any help would be much appreciated!
Is the font an RSC font or a TTF Font? If its a TTF, you might be able to look it up in Windows Character map. If its an RSC, can you use the Insert Symbol dialog box to see if the % character is mapped somewhere else.
Are you using MicroStation or SignCAD. In SignCAD this is a standard sign and the Percent is already there and the % key from the keyboard works.
Mike LongstreetVermont Agency of TransportationCivil Engineering Technical SupportVTCAD Help
