Is there a way to remove the +50 STA cross sections from my cross sections that I've already cut?
So I'd only have 100' increments. Besides manually deleting them all, of course. I have a lot of cross sections to deal with so I'm trying to avoid that.
Thanks!
If your using ORD, it might be simplest to delete them and re-create them. If its a long road project, the User is dependent on the Cross Section Drawing Models being placed on the Sheet Models correctly. Its just not feasible to manually reconfigure Drawing Model references in the Sheet Model for longer roads.
In general, I've found that the User has one shot to "cut" cross sections correctly. If stations are missed or need to be deleted, it can ripple through all sheets. Overall, cross sections are the biggest pain about this software.
