Currently we're using OpenRoads 2020 R2 Update 8. The client and PennDOT are using ORD 2020 R3 Update 9. Apparently it is a good idea if both you and the client (or team member) are on the same version, usually the most recent.
The good people who handle updating software and keeping the system humming went to the usual site, but couldn't find ORD 2020 R3 Update 9. They did find ORD 2021 R1.
So the question (or questions) is: where did they put ORD 2020 R3 Update 9? Is it still available?
Thanks!
Hello Mark,
When they arrive to the OpenRoads Designer Downloads Page, they will need to change the Version picklist, then click Apply.
ProjectWise Explorer CONNECT Edition, Version 10.00.03.453
ProjectWise Drive, Version 2022.1.328
OpenRoads Designer CONNECT Edition, Version 10.09.00.91
OpenRoads Designer CE 202 Release 2, Version 10.10.21.4
Power GEOPAK V8i (SELECTseries 10), Version 08.11.09.918
I knew someone would know! I'll pass this along.
Thank you, good sir!
