ORD 2020 R3 10.09.00.91
I'm running into an issue where my "Measure Length" tool is giving me an incorrect value. I am trying to measure a length of conduit, but it is giving me a length double of what the actual length is. I had it defined as an offset partial off the back of a sidewalk. Has anyone ever run into this before? It's an issue if I can't trust the measure tools.
Thanks!
Ben
Please check if you are measurin in "View Z" mode and not in "Global Z" which takes Z level in consideration while measuring.
Just curious, what happens if you turn off display of custom linestyles?
Not sure where the "View Z" / "Global Z" option is shown on this dialog....? I tried all of the "Flatten Direction" options and no dice. Also, where would you find turning off diplay custom linestyles? This is getting a little advanced..
when you click measure tool a tab docks to the left (usually, search it in your window)
For Switching off line style
Thanks for the suggestion Ramanan, unfortunately turning off the linestyle did not change the value from the Measure length tool.
