I am using Power inroads SS10. I have attached a dgn with smart elements and corridor. I created surface in the active file from the referenced file.
When i delete few features in the referenced file, the deleted features does not go away from the surface, inspite of updating the reference.
Please help if there is a wasy to remove deleted features from the surface.
Ramanan
You may need to remove the rule for the Terrain so that you are allowed to edit it, if it was built from Complex.
Eddie Giese, PEProduction Manager | Senior Roadway EngineerLicensed in FL & PAACEC FDOTConnect Instructor on behalf of FDOT
Patel, Greene & Associates, LLC PowerGEOPAK V8i SS10 (08.11.09.918)OpenRoads Designer 2021 R2 (10.10.21.4)OpenRoads Designer 2020 R3 (10.9.0.91)ProjectWise Explorer CE 10.0.3.453LumenRT CE Update 14 (16.14.60.98)
Thanks for the reply. The terrain is not a complex terrain. The terrain was created from elements. The elements are in reference file
