Hello,I've ran in to a little issue where only thing not clipping according to a culvert template drop isn't clipping cause it's an invalid geometry point. Is there a workaround for this issue?
What software, and what version of the software (specific version number) are you using?
While I do not have a lot of experience, a surface template is not a corridor. If the tool is looking specifically for a corridor, then a surface template won't meet the criteria. There may be another tool you could use, but I can't say which one.
MaryB
I'm on ORD 2021 R1 10.10. Yeah it's weird that you can physically mover control points for the surface template's layers but there's no tool to reference them with a 3D underground object like a culvert in this case.I was thinking I probably will have to adjust my design solutions where the civil cell ends right at the end of the radius and put my culvert there and then a new corridor begins which should be able to be clipped accordingly.
The solution to this problem intrigues me, thank you for sharing.
