Hello,I've ran in to an issue where corridor will malfunction and create a inappropriate geometry anomaly.
Happens after clipping.
I've solved the issue: You need to move the offset responsible for referencing the corridor edge of pavement/shoulder by few milimeters which can be done using the handles and then just re-clip the corridor.
Answer Verified By: Reinis Labans
