Corridor processing speed
I have a very long corridor (aprox 18km) where I  am trying to model some fill around some tunnel elements. For that I am using parametric constraints and key stations so I can keep my number of templates to a minimum and the template drops the same.
But lately I have noticed that my model is painfully slow. If I am trying to draw some civil geometry like a simple line, it takes around 1-2min to process and it's just a simple line. Also when I change the stationing for a template drop or do a new one it takes a long amount of time.
To be fair so far I have 154 key stations, 36 template drops and 200 parameters and I am only at a quarter along the alignment.
So are there any settings to sped up the model? I am using OpenRoads CE 2020 R3. Thank you.
