As you can see below the offset's are not correct. I only have it displayed to the 10th but it is off by 0.0615088. The elevation is correct.
The offsets are suppose to be 4.0' and 17.0' each side of the center line.
I don't know if I need to change something in the .XIN file or if it is something in the annotation dialog box.
Is the linework at exactly the correct location? Is it possible that the annotation is correct and the linework is slightly off?
MaryB
Are you cutting your cross sections at even multiples of your modeling interval? This could cause issues as the model will be chorded around curve sections of the alignment and may not be modeled right on the alignment.
