Hi
I wonder if there is any configuration variable that could set up OpenRoads Cross sections to be updated to the Design Model content settings.
I have number of XS, clickling each and setting Synchrozize View to Settings From Design Model would be a massive work.
Thanks in Advance
Using ORD 2021 R1
Hi Adam,
We have updated all our Sheet Seeds to use this setting and all new sections naturally have them during creation.
Regarding a variable, the only one that looks like it would do this is:
MS_REF_DEFAULTSETTINGS = synchWithSavedView=none|volume|allsettings
but you can see the options in Help do not indicate an entry for the new setting.
Mark
OpenRoads Designer 2022 R3 (10.12) | Microstation 2023.1 | ProjectWise CE 3.4
Answer Verified By: Adam Wieczorek
Some further information is available here https://www.youtube.com/watch?v=8MQ1rQ168qk&list=PLnJUnxLwu_N7ThhmfkTRw2WShEWT46GCO&index=11
I was also wanting a way to change this on drawings that had already been created without custom programing. I was thinking about a Batch Process with keyin REFERENCE SET SYNCHWITHSAVEDVIEW=ALLSETTINGS|VOLUMEONLY|PRESENTATIONONLY|NONE <file_spec>, but similar to Mark's comment on the config variable, the new setting does not have a keyin option. I submitted enhancement #1135490 for this.
Matt
May I ask how this setting was done? How did you accomplish this?
Thank you!
