Hej
I am struggling with slope annotation for on cross sections. Basically I would like to create list of points for segments to be annotated with slope.
For some reason all segments are annotated. I have few adjacent corridors there - so is there a way to annotate slope with two pints that are not from the same corridor?
Also even if Points are chosen from template it will not work. It has been a time since I last defined XS annotation group but I think it used to work - the only problem I had in the past was to annotate slope or distance between 3D linear objects that are not from corridor.
Any tips highly appreciated :)
Adam
Hi,I have a similar problem with annotation XS in ORD 2021 R1 versus 2020 R3. Same Annotation Group, different result - see examples below. The point filter does not seem to work.For this reason, I still stay in ORD 2020 R3.
RegardsJan
Yes. Unfortunately it is a bug that has not being identified early enough. I hope it could be part of priority build.
I apologize for this very annoying bug.
hi, what is the process to get priority build? I had no idea this is a bug and spent non-billable hours on project trying to fix it with no success.
Best,
OpenRoads Designer 2023 | OpenRail Designer 2023
Out of curiosity, do your filters include the "on_top" option? I have seen some interesting things with annotation inconsistencies and upon occasion, simply removing that have gotten closer to my desired results. I haven't had time to dig too much into, so just curious.
Steve
www.envisioncad.com
ORD - 10.12.02.04 / 10.10.21.04 / 10.10.01.03 / 10.08.01.33Power GEOPAK / Power InRoads - 08.11.09.918Civil 3D - 2021 / 2022 / 2024
without on_top option nothing is annotated, all segments are ignored. With "on-top" turned on, all segments are annotated plus some of lited that are not realy on top.
