I've ran in to an issue with my templates where OR doesn't draw all of the lines on 2D pane. I fallowed several suggestions from the community to work in 2D and then adjust 3D only when necessary.Corridor projects it's lines after applying different templates several times eventually it will display lines but linear templates do not seem to work at all while in 3D view it seems to have drawn everything.
In addition these settings for Linear geometry are enabled and templates present in the file.
Alrighty,So the issue stems from having a .dgnlib failing to keep up or something technical like that.I have edited my "Common Features Annotations Levels Elem Temp Item Types Metric.dgnlib" to contain Desired Levels, element templates, feature definitions and symbologies in that order. According to these templates I have made several corridor templates with layers and points based on the self made styles. Also I have several corridor templates I had made previously based on similar but not a seed file definitions. After adding a template based on dgnlib features most of the lines do not display on the 2D drawing but after adding a template which is whited out cause the most of the features are not present it DOES draw all of the lines and then adding the featurized template it adjusts the lines to the right positions with the right styles.?
I assume that this is not how it's supposed to work because after reinstalling whole Bentley suite the issue persisted and hopefully this helps someone.With regards,Reinis
Hi, Please check the suggestion in this forum. It might solve the issue:
RE: My overlay/striping section disappreas when I change corridor from "design" to "final top mesh"
