Aerial Background Image issue
Bing Maps is crashing the file when attaching in raster manager. It also crashes when turning the BING aerial on.
Also, Bing Maps is not plotting correctly in pdf. The version of ORD I am using is 10.10.1.3. Is there any issue with plotting on pdf where the aerial shows as several squares of the same picture tied together?
Thank you in advance for your help.
